Allocating memory for an internal data structure for communication to the PHY failed. This usually happens when the system is running out of memory.
Run "show memory" command to further debug this problem. The problem may be resolved by deleting some configurations, retrying the operation or reboot.
Error
Failure to allocate memory for object %object% for phyId %phyId%
| Name | Type |
| object | String |
| phyId | uInt |
